RFC2461 states that Router Advertisements must contain a hop limit of 255, but a packet was received which did not. This means either that the other router is misconfigured and is sending the packet with an invalid hop count, or there is a network problem causing link local ICMP6 packets to be inappropriately routed.
No remedy is available.
Warning
received bad Router Advertisement on vlan %vlanName% from %sourceAddress% : hop limit (%hopLimit%) is not 255
| Name | Type |
| vlanName | VLAN |
| sourceAddress | IPv6 |
| hopLimit | uInt |
